2021.01.14
Highlight for this release are the new Multiplier Nodes!
- ADDED Multiplier Nodes Animate in bulk with this nifty utility node!
- ADDED Environment variables Gain more control over the integration of Ragdoll into your pipeline
- ADDED Dynamic Shape Type Attributes Cleaner channel box means happier animators
- FIXED NaN and Dynamic Control Got bogus values on the
Rotate Limitof Dynamic Controls? No longer! - FIXED Cycle warnings on create In rare occasions, Maya would complain that there's a cycle just as you turn a control dynamic. No more.
- FIXED Zero limit strength Used to be interpreted as "inifinitely strong", but now is "off" as one would expect.
- PUBLICITY EnTT We got mentioned in this great project :)
- OPTIMISATION Bounding Box Minor performance and stability improvements with native bounding box support
Multiplier Nodes
Work procedurally, with this centralised place to edit any number of rigids or constraints simultaneously. The idea is to facilitate a top-level node which govern the overall look of your simulation; withouth having to find and select each control individually.
Workflow
- Select any number of rigids or constraints
- Click
Multiply Selected Constraints(orRigids)
The order in which you select matters, the first selection gets the node. The recommended workflow is to start with the root and work your way out. But your selection can span multiple hierarchies or even the whole character. A quick "Select Hierarchy" across an entire character is possible also.
A constraint and rigid can only have 1 multiplier connected at any one time.
Demo
The most common attributes are made available currently, let me know if you find something missing!
YouTube
Environment Variables
Added these suckers for you to play around with.
| Variable | Description | Default |
| RAGDOLL_PLUGIN | Absolute path to binary plugin, .mll on Windows .so on Linux. This overrides whatever is on MAYA_PLUG_IN_PATH |
"ragdoll" |
| RAGDOLL_NO_AUTOLOAD | Do not automatically load the plug-in and add the menu on startup of Maya. | False |
| RAGDOLL_NO_STARTUP_DIALOG | Do not display the startup-dialog on first launch. | False |
| RAGDOLL_AUTO_SERIAL | Automatically activate Ragdoll on install using this serial number. | Unset |
For up to date information, see here.
EnTT
Getting some more recognition on the interwebs from EnTT, the library used to keep Ragdoll fast and clean!
Now only relevant attributes are visible in the Channel Box, dynamically based on the current type.
I've added an option to disable this in the Global Preferences.
Bounding Box
Maya uses bounding box information to avoid drawing things that aren't visible in camera. The previous version of Ragdoll didn't provide Maya with any bounding box, which left Maya with no choice but to draw these always; even when behind the camera.
Now this isn't so. You shouldn't notice much for smaller scenes, but drawing typically consumes 20-30% of the total CPU impact Ragdoll has on your character rigs. So for larger scenes this should reap a significant performance boost.
Pro tip: You can also disable drawing of all Ragdoll primitives by disabling
Locatorsin your viewport; that's how Maya classifies any and all Ragdoll nodes.
Cycle Warnings
TLDR; you should now experience fewer cycle warnings.
Whenever you create a rigid from any Maya node, like an animation control, Ragdoll makes a note of the position and orientation of that control. It takes into account that you may not be on the start frame when you create the control, which is what you most likely intended to do. When that happens, Maya will silently roll back time in the background to query an attribute at the start frame.
This silent roll-back has a tendency to trigger evaluation of unrelated nodes, like IK handles, which in turn trigger other nodes, ultimately leading back to where it came from, and thus cause a cycle. These were somewhat harmless, but could mask a real cycle from happening.
In this release, this silent roll back only happens when you actually aren't on the start frame. So you should see less of it. There's still room for improvement however, so if you still find warnings or any odd behaviors being due to cycles, do reach out!
NaN
If you've ever gotten these, you can now rest easy. They are gone. They could happen on occasion, especially after repeated undo. It had to do with memory access violation by Maya being naughty, something it really shouldn't be able to do in the first place. We now guard against this, so all is well.
