2021.03.23
Highlight for this release is JSON Export, this one's for you game developers out there!
- ADDED JSON Export Run your ragdolls in Unreal, Unity or your own custom game engine
- ADDED Active Chain Next generation "Dynamic Control" with "chain"
- ADDED Dynamic Constraint Attributes Stay focused on attributes that matter
- ADDED What'Z-Up? Is your up axis-Z? Ragdoll is now down with that.
- CHANGED Simplified Menu Less noisy, more focused menu
- CHANGED Dynamic Install Tighter integration into Maya's native Plug-in Manager
- CHANGED Greater Guide Strength Have simulation follow animation even closelier
- FIXED Less Crashes Kids, say no to crashes
- FIXED Custom Rotate Order Now works as expected
- FIXED Bad Initial State on Load Loading saved physics now works as expected
Important!
This version won't self-install like the past releases, see Dynamic Install on how you need to load the plug-in via Maya's Plug-in Manager from now on.
Ragcar
It's a ragcar allright. You can tell by how bouncy it is!
Knocking things around
No obstacle is too tall for ragcar.
A look underneath
The parts are all there, it's how it would work in real life if you put an engine in it. :D
Vehicle model from Mecabricks.
JSON Export
In 2021.03.01 we introduced cmds.ragdollDump
to get a copy of all rigids in the form of a JSON dictionary.
This release includes all initial state for the simulation, such that you can reproduce the results you see in Maya in a game engine, like Unreal, Unity, CryEngine or your own custom game engine. Or why not Houdini, Blender or 3dsMax?
This enables you to use Maya as an authoring platform for physics anywhere.
from maya import cmds
dump = cmds.ragdollDump()
# Convert big string to structured dictionary
import json
dump = json.loads(dump)
for entity, data in dump.items():
components = data["components"]
name = components["NameComponents"]["members"]["path"]
print(name)
# |root|pelvis|rRigid1
# |root|pelvis|spine|rRigid2
# |root|pelvis|spine2|rRigid3
Here's an example of what to expect from the output.
"entities": {
"10": {
"components": {
"NameComponent": "upperArm",
"ColorComponent": [1.0, 0.0, 0.0],
"GeometryDescriptionComponent": "Capsule",
"15": {
"components": {
"NameComponent": "lowerArm",
"ColorComponent": [0.0, 1.0, 0.0],
"GeometryDescriptionComponent": "Box",
See the new Serialisation documentation for an overview, examples and data reference.
Dynamic Install
Previous releases shipped with a userSetup.py
that triggered on launch of Maya. This made it easy to get setup, but made it challenging to uninstall without physically removing files off of the file system (hint: ~/Documents/maya/modules/Ragdoll.mod
This release associates install with plug-in load.
Install
Uninstall
Active Chain
Dynamic Control has been renamed Active Chain
Turns out, what Dynamic Control was really all about was a generic chain that can also be turned into hierarchies of chains - or "branches" - to form a tree. Even a literal one!
Now whatever attributes are relevant show up in the Channel Box, and stay relevant as you make changes. Similar to how the rdRigid.shapeType
attribute updates the shapeExtents
and shapeOffset
attributes!
What'Z-up?
Ragdoll now understands when the up-axis is Z rather than the default Y.
Simplified Menu
Items have been re-arranged and grouped together to be easier to find and less cluttered.
The solver Iterations
determines how high your Guide Strength
attribute can go. Per default, Iterations
was set to 1
which enabled strengths between 0-5
or so until their effect dimished.
This release increases this default value to 4
for ranges between 0-100
, which means "incredibly high!". The change comes at a minor performance impact - estimated between 1-5% - so if you find the need to optimise, lower this value back to 2 or 1.
Hint
Bear in mind that the number of iterations are spread across all rigid in your scene. Meaning twice the number of rigids would half the amount of iterations dedicated to each one.
Crash on Cleanup
In rare cases, Ragdoll could crash Maya due to accessing memory it had no business accessing. Those have now been patched up and refactored for a more stable, crash-free experience!
In rare cases, opening a scene could lead to some controls being badly positioned. This could happen if the control you made dynamic was parented to a group with no values. That made the parent and local matrices cancel out, producing an identity matrix. Maya doesn't normally save attributes that are equal to their default values, and this includes matrices whose defaults are the identity matrix.
Rotate Order Improvement
In previous releases, any rotation order other than XYZ (the default) would make your rotations all whack. Ragdoll didn't know how to translate physics into any order other than XYZ, so it would put them in the wrong place.
In the last release, I added a warning for that and in this release I've lifted that warning somewhat. Most rotation orders works well, but I have spotted rare instances of one axis flipping.
Here's the problem.
See how arms and torso flips? It tends to happen around the 90 and 180 degree values, values below that normally look fine. This will be fixed in a future release, one way or another!
